This command displays the global IS-IS configuration information as well as a summarized router process listing.
N/A.
The displayed global configuration information includes the restart enablement, restart grace period, and import-policy setting. The router process listing includes the area name, system ID, whether it's enabled, the IS type, and a count of associated interfaces and area addresses. This command applies only to the IS-IS router processes running in the current virtual router.
The following command displays IS-IS information:
show isis
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
